We are only virgin media area so have the underground routes in place. Here’s hoping.Not sure if it’s something to do with the area I live in, but they are using existing underground routes (presume the same ones the phone lines use?)
Hello fellow Davenporter! They haven't quite finished doing our corner of The Crescent yet, they need to hurry up!
Virgin was never installed in the street, even though the road was built in 2001, perhaps they installed the ducting for fibre etc but it didn't get used or just got used for the coppper phone lines? Not sure reallyWe are only virgin media area so have the underground routes in place. Here’s hoping.
Yeh. What’s the reaction from the neighbours ? Do you know if they were told prior to installation of the poles?BRSK have put a several poles in my area
i presume they run a fibre cable from the pole to your house overhead?
I'm not personally aware of any complains but saying that my nearest pole have been there for years for BT Openereach.Yeh. What’s the reaction from the neighbours ? Do you know if they were told prior to installation of the poles?
FTTP. Nobody needs to dig up streets if you already have Openreach ducting to your house because BRSK can rent space in that. I have Lit Fibre and no roadworks for Lit ever appeared. Openreach are doing FTTP now and no roadworks appear, because they're just opening up chambers that are already there
It's not so much they only use poles, it's that they use Openreach PIA, so it's whatever openreach infrastructure exists to your houseOh wow. I did ask them but the they said they only use poles.
I was wondering the same, my brsk is getting installed this afternoon, and I'd prefer to use my own router for the phone. Have you checked if you can get the config from their provided router? I think you have full admin access. This is something I'll be looking at after the Engineer has finished!Does anyone here use there own router with the BRSK BetterPhone Service and broadband?
I was wanting to use my own router with the betterphone service however support won't share the configuration to allow it??
Same for meInstallation day has arrivedwill post speed tests when I've got it all set up.
Will doSame for me
Let me know if you manage to find the betterphone configuration
I'm going to ask to engineer about it
Yep I would be fine doing that, but brsk say the phone needs to be plugged into one of the rj11 voip ports on their router.I don’t use the phone but did plug my AX68 router directly into the fibre hub and ditched the Brsk router. No issues and worked immediately.
