Build 6 Bitspower SM8
A few updates
- Pump inlet hole drilled and fitted
- Drain fitted
- Tubing draft complete - Any thoughts?
please excuse iphone pics - not the best
Love the bending what did you use ?
Tube routing looks awesome very clean
My step drill piece looks massive compared to yours and a lot safe
Mine looks like it will eat my mid plate up!
As ever beautiful build m8 :)
Thanks mate. I don't use anything for bending just the inner tube bender and heat. It's decent stuff to work with after a few goes. I just line it up by eye and allow an inch each end then cut to size.
Step drill will be fine just keep it on a lowing speed if the teeth look aggressive.
wow that loosk amazing, love the case, tubing, everything just looks good! Thats not a PC its SPC (super personal computer :P)
Your right it they do look mean!!!
Did you mask the surrounding area? Before stepping! ;)
I've been practicing bending for a while used all sorts of different things
From shops and around the house lol.
Your thoughts on the case, best one u had?
Was thinking down the road at some point was going to try caselabs
