Do the Blue Peter test - ClickyThe cryorig c1 will fit with a 25mm fan, but just need to make sure that the mobo placement means that the vent hole on the side cover matches up with the cooler.
Done that already. Only tests to see if the cooler will fit the board (it will). But need the actual case to see if the holes line up (oh the innuendos)Do the Blue Peter test - Clicky![]()
Hehe - hope so (nice design) - and it keeps you on track for attempting to fit the seemingly unfeasible into an ever diminishing space.Done that already. Only tests to see if the cooler will fit the board (it will). But need the actual case to see if the holes line up (oh the innuendos)
Work in the NHS. We're all masochistsyou do know you're meant to relax in your down time.
LOL was just about to post this if it's of any use:Work in the NHS. We're all masochists
#racist.Recommend muting
This might give you more room to play with:#racist.
(Fyi I speak/understand mandarin lol)
Cryorig c1 is 74mm with fan and fan shroud. 13mm thick fan, and 2.4mm shroud according to what I've found. So essentially <59mm high when it's naked.
Rvz03 has 83mm clearance so hopefully should fit a 83.6mm HSF within build tolerances...(hopefully) lol
But yes, I've deliberately bought the non-argb version because of that silly argb controller. And not that I'm particularly partial to argb anyway
Did not wish to presume. #diplomatic(Fyi I speak/understand mandarin lol)
Do none of us sleep?This might give you more room to play with:
Scythe SCBSK-3000 Big Shuriken 3 CPU Cooler - 120mm
Sleeping is overrated, right doc @tamzzy?Do none of us sleep?
Kinda, but still with a 25mm fan, height is 80mm. So 3mm gap will need to be bridged by a duct or shroud.This might give you more room to play with:
Dunno about you, but I'm on nights soooo...Sleeping is overrated, right doc @tamzzy?
He's busy trying to raise the dead after his mass genocide due to lack of memory resources on his old system.Sleeping is overrated, right doc @tamzzy?
Yep, sat on a coma patient flicking through forums.Dunno about you, but I'm on nights soooo...
Well nearly right... 13 coma patients actuallyYep, sat on a coma patient flicking through forums.
That seems a poor reflection of your skills...Well nearly right... 13 coma patients actually![]()
ooh ouch. White argb rvz03 is expensive.Think I'll be following @tamzzy in the way of the RVZ03 .. but ARGB because if the kids, Nd white because all things IKEA
Ended the shift still at 13. Not killed anyone lolOK, I need to get at least 4 hrs sleep.
Enjoy the remainder of your shift @tamzzy and try to stick at 13 unresponsive - 14 might start to look careless...
Ended the shift still at 13. Not killed anyone lol![]()
