- 12 Sep 2012
Ive took the cooler off, Now ill need to remover then put more thermal paste on yes?
If you take C drive from another pc, unless the specs are very similar then it will simply give you a BSOD during windows boot up logo. That's the case for me 100% of the time. It may work, it may not, but it's always a good idea to re-install anyway for a new build, especially when you have a SSD.
Yes. Uplaod a pic, so we can see how much you are using.
That only happens if you're not thoroughly getting rid of any drivers before transferring.
Do you really need to add more thermal paste every time you remove your heat sync even if its only been on for 3 minutes?
Do I Put it on the cpu or the fan? when it came the thermal paste was already on the fan, but when I put more paste on I put it on the cpu like I saw in a video
Can I use my finger to spread?
I'm just a bit paranoid now because i had to eff around with my heat sync loads trying to get it to sit, i had to remove it like 3 times and i only had a tiny sachet of thermal paste and i don't have any more. For the record thermal armour on a motherboard may look cool, its a LIVING HELL trying to install a sizeable heat sync on it.
I use an old credit card or something similar.
I don't bother. A sensible sized blob of compound in the middle of the CPU and normal mounting pressure works well enough. The coverage always looks fine when the cooler is removed.
