I have quite a few mods installed but they make oblivion run like poo ( better cities , qarls texturepack etc)
Thanks for putting this together, it helped me learn quite a bit about the mods.
Took me a day to install everything off your post then took another day hunting through mods to install on top ^^
A few things though. git doesnt work when any of your mod files have japanese / korean text. So after a few mods I was unable to use git anymore
Once I have all my mods etc installed can I simply copy the oblivion directory and thats it, it will all be backed up and I could take it else where and run it from the oblivion exe and all the mods would work?
It only seems to **** a brick when files are in Japanese, delete the one or two text files with it.
I unzipped into the oblivion folder using winrar, opened oblivion using the launcher (this is a disc install of the game), started a new game and quit before leaving my cell but I can't see any log file. Any ideas what I've done wrong?Oblivion Script Extender (OBSE) v0019b
The next piece of the puzzle is OBSE, this is a plugin for the Oblivion engine that allows people to extend its functionality. This build uses it for a few different things, mainly to improve stability and enhance graphics.
It's trivial to install, just unzip into the Oblivion folder. The Steam version doesn't need anything else doing. Check the readme for a Disc based install as you might need to use the loader.
Now would be a good time to startup Oblivion to see if it's working; exit out of Oblivion and check your Oblivion folder. There should be an OBSE log file there, indicating all is working.
, more thanks to The Halk his suggestion on data file in Oblivion data folder help me find out 3 mods i had installed wrong
ive followed your guide and installed most of what you suggested, game runs fine apart from the occasional ctd, only problem i get a lot of the yellow stars saying missing meshes any idea on how to sort this?
with regards to your problem Ginger-Menace, correct me if i'm wrong sldsmkd, but i think that with some mods iirc you have to download a seperate texture pack which is not always made clear in the descriptions. Maybe you have missed one of them.
(you have probably already mentioned this, but i made the mistake with a few mods when i fist played it)![]()
