Yeah I've had to dump that folder (11,000+ files!) as my fps was horrendous. Would love to be able to use LODgen though.
Wait for the script
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
More problems....since Better Cities my FPS in parts of the Imperial City drops - I kid you not - to around 5 fps.
Is my computer really that feeble??
I've ran into a probelm with All Natural (Well it happens with Bettter Citys, but that needs All Natural to run anyway), Oblivion is just closing straight too desktop everytime its launched, Oblivion works fine with all the other mods I've installed though
Better Cities doesn't need All Natural to run. Read the docs, make sure you've installed it all correctly and run Boss (READ THE OUTPUT WITH A FINE TOOTHCOMB), rebuild Bashed Patch.
I got it too work by building it as a OMOD in OBMM![]()
BTW: to respond to the question about the next update. I'll update when we got MSAA on ATI working or definitly rejected. I optimized a lot of the effects, so actually in reality it should be a real performance update (if nothing else).
When RAEVWD runs it generates *.LOD files in Oblivion\Data\GeneratedLOD - each one corresponds to a cell on the map. (You can see X and Y coordinates in the file name).
I've cobbled together a whitelist of cells that have something of interest in them and are in the more open areas (so not behind half a mile of forest). The script just deletes the LOD from areas you are less likely to see. It has around 60 cells whitelisted (out of maybe a 1000) - helps framerates a lot. It means you may get statues and such popping up - but the key dungeons and landmarks should stay viewable when distant.
It does the same thing as some of the other VWD mods, but uses the much improved meshes from RAEVWD. (The other mods just display the full detail meshes)
Whoooaaaaa
I just "discovered" that you can enjoy HDR with AA! Yay!! Just on a whim I decided to try it out and it wooooooooooooorks
You need to go to your GFX card software (Catalyst for me) and de-select Application Settings for AA and then set the AA from in there.
Whooo hoooo now HDR+AA = Oblivion looks fantabulous.
Altho Im guessing most of you lot know this already huh lol. But for the sake of others who might not know what Im bleating about:
Oblivion itself does not allow HDR + AA. So while HDR can look good you get the jaggies. But using ur GFX card app you can get around this![]()
Bump OP, have you paused on this for now?
