Canadian Grand Prix 2012, Montréal - Race 7/20
Why did it take so long for McLaren to fix JB oil leak/gearbox?
What happened between Vettel & Senna?
JB lost most of P1 due to an oil leak that got fluid on the clutch. Then during the break between P1 and P2 they discovered a problem with the gearbox itself and so had to change it, meaning he lost most of P2 as well.
And Vettel tagged Senna I think. Got a slapped wrist.
Thanks, just been catching up on this.
Ferrari quotes from friday practice:
Sounds promising. Ferrari were supposed to have poor traction and a real lack of top speed at the start of the season if I remember correctly? If they're strong here then it would indicate they have really got on top of the car. :)
In monaco they showed amazing mechanical grip. It's something that was talked about in FP at that event and in FP1&2 in Canada.
Anyone know if you can watch Sky Go on Android phones, specifically Samsung GS3? I'm going to a friend's party for footy tonight and want to watch the qually at the same time.
-- edit just read it's not supported on icecream sandwich ! ;\ Have to see if I can watch it on my mate's laptop instead.
but its the same as mercedes system so if it goes wrong they cant just grab another nut and your out of the race?
They'd have to change all 4 wheels again as you can't change just one.
Oh, and Jenson had his gearbox changed twice!
Whitmarsh said:
For Jenson, clearly, today was rather more troubled, albeit through no fault of his own. He suffered an oil leak in this morning's session which necessitated the removal and re-fitting of his gearbox. Then, prior to this afternoon's session, we diagnosed another problem and as a result we had to change his gearbox yet again.
no its poor quality control or poor materials
The best QC in the world can't pick up every single fault.
Is an undetectable defect bad QC or bad materials? Answer: Neither.
Probability states things WILL fail.
Lady luck comes into it because who knows where the fault is?
Given Mercs engine reliability, I'm guessing it really comes down to poor design as QC and materials will be top notch in their gearboxes, as per their engines.
