It may change automatically for Asus boards when running the ram and fclk out of sync, I know for some there is an option to set the dividers UCLK==MCLK or UCLK==MCLK/2 are the two options on my MSI board etc.What do you mean 2-1 mode?
1.45 is moderately high but 1.5 is about as high as I would go.Will gave to give that a try. The XMP profile auto sets dram voltage to 1.35, I've tried 1.4 one time and it hard crashed and lit up yellow fault indicator light on mobo (RAM error) haven't messed with the voltages since. I've seen some people say 1.45 or 1.5, is there a chance I'd need to tune that too or just the soc voltage?
3733 is fine. you didn’t lose the lottery, that’s just about where most top out at.No matter what I do, I can't run my ram faster than 3733 with 5600X. Anything quicker and I get WHEAs.. I guess I lost silicone lottery with 5600X.. At least I tightened timings to 15-17-18-18-35, latency in Aida is 58ns..
OP can’t do 3600. That’s losing (if his issue is the MEm controller)
If you want 4000+, you need the get the 4750G which has an amazing RAM controller in it.
Crucial ballistix is micron - it’s cheap, AMD processors love it and it clocks high.I had the same RAM, save yourself a headache and return it. I tried everything I could think of, relaxed the timings etc. It's cheapo samsung chips and for whatever reason the new AMD processors hate it. A friend had similar issues with a corsair kit that has the same chips.
Get the Crucial Ballistix 3600 C16 set. I've had one WHEA error in 9 months.
Tbh the ram won't make a huge difference unless your running 1080p with the graphics turned down, if you cant get 3600mhz running then try 3533 3467 3400 3333 etc until it's stable then try and tighten the timings a bit.@JollyJamma the more I see people having issues with the 5600x, and the small info I have found on the Patriot Viper 2x16 3600, the more I think I just need to throw the whole thing out and start over. . Lol
I have the Asus Tuf Gaming x570 plus (wifi) seating both of those, with an amd 5700xt 8gb, and the whole rig does alright gaming on 1440p, but I've just always felt like it should be doing BETTER. And so I've always wondered if the RAM and their inability to run xmp at their spec was holding me back as much as I feel like it is. But I've never known enough about the technical stuff of OC'ing like timings and voltages to be comfortable enough to do it myself and not mess something up, or enough to know what to do outside of sucking it up and dumping more money into it that would make a noticeable improvement or an improvement at all
Where do you stay?Yeh loaded the xmp and manually set 1.35 also tried 1.36/1.37 no luck.
Best timings iv got is 3200 16-19-19-38
Ram rated 3600 18-22-22-40
No idea what fclk is.
I was told to run 3200 or 3600 so everything is in sync?(?)
90% of the time it hangs loading windows. Made it to Windows once and then immediately crashed
Have the same problem with an Asrock b550 Phantom ITX and a 5900x. Cant get my crucial ballistix past 3200mhz despite being a 3600mhz kit, setting it to 3400 prevents even bios access. How did people get past this ?
