I haven't overclocked it yet!
Sorry guys, didn't realise there were new posts. Spec is:
- 2 x MSI HD 7970 Lightning BOOSTED Edition
- Intel Core i7-4770K 3.50GHz
- H100i CPU Cooler
- Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard
- Samsung 250GB SSD 840 SATA 6Gb/s Basic
- Seasonic X-Series 750w '80 Plus Gold' Modular Power Supply
- Corsair Carbide 540 High Airflow ATX Cube Case
- TeamGroup Vulcan ORANGE 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit
- Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache
- 5x Alpenföhn 120mm Wing Boost Plus PWM Fan - Orange
- 1x Alpenföhn 140mm Wing Boost Plus PWM Fan - Orange
- NZXT Hue
Regards the Haswell, I haven't much to compare it too, my last CPU's were a 920 and an 8120.
Ether, I fitted the fan wire, was better to consolidate the wires. The PC is done now, I put these two in the 540 build pics:
Now I just wait until I've moved house and can have my 3rd 120hz monitor
3rd 7970 ?? What games do you play? Does the NZXT Hue come with its own paste or how do u install it? Nice build btw.
Sir, your H100i backplate is the wrong way around.
The indents you have on the right should be facing the screws on the top, gives a better fit and possibly better temps.
If you care
ethermaster also sold me on this setup, only difference being I'm waiting on my 280x toxic's to build. I was going to make a build log but being so similar this seems pretty pointless so if you have any tips for the build that would be great.
I'm unsure how to go with fans now as I want dust resistance, hows yours holding up?
I also bought the c11 ram, is this going to cause problems?
