Pfft. I started on BnH Gold at 16. I smoked for 4 years and this January I stopped. Just will power.
This man speaks the truth...sadly my bro just got back his honeymoon so instead of picking me up the usual silver B&H...hes only got me the gold ones :/ and i havent smoked them for a good few yrs now...smoked a few and felt like throwing up my lungs.
Seriously if you want light cigs then Silk cut are the ones..go for the ultra light ones and you should be fine. Problem with Silkies is that they are a bit too light for me...id rather much breathe air than smoke them and if i have to smoke them then i usually tape up the filter ie cover the holes. I just cant get a decent hit from them. Silver B&H's are the best ones for me.
Marlboro Lights
Lucky Strike Silver
Camel Blue
Lucky Strike!
Silk Cut - although after smoking B&H gold, you'll have to smoke three at once.
Yes, so I heard.I think there is a bit of a myth that smoking "light" cigarettes is somehow better for you. Wrong.
LINKY
Never tried Lucky Strike, might give them a go (just read that the silvers are becoming blue)
So guess the choice is either:
Malboro Light's
or
Lucky Strike Silver/Blue
LINKY
Er, and Camel Blue as has been mentioned about five times - definitely more than Lucky Strike, which are okay but not a patch on Camel Blue.
