- 20 Oct 2002
- In a house
Think if I'd have stripped it down that far I'd have got a leccy start C90 lump & a "thumper" exhaust on it. It's not fun unless you are disturbing everybody else on the camp site, waking babies 5 miles away & getting dogs to chase you like they have rabies.
/joke (Before the Brigade attack me)
lol, i would love to change the engine, but at the moment its a bit of a pain, as its a 6v version. I just want to try and get it on the road initially. I might have a looky at an 88cc kit (piston/cyclinder) at a later date. I could possibly go down the 125 juncheng route though....
ANYWAY
I was having some issues getting the cam sprocket back on its seat, as the cam chain seemed to be too tight. I tried all manor of things, and then threw a strop and gave up for a couple of days.
I posted on a forum, and found out that you have to remove the cam chain tensioner from under the block before you try to re-fit the cam sprocket.. Duhhhhh...
With this in mind, the engine went back together perfectly! This allowed me to move on to a few other bits and bobs...
It was late, so I was a bit lax with the picture taking...
Progress:
Engine Fitted/Built up
Engine Timed up (i think)
Carb fitted
Exhaust fitted
Seat almost Fitted (one bolt missing, need to locate one)
Reat light fitted/connected
Loom Almost completed
Handlebars fitted
Brake Levers fitted
Footpegs/stand fitted
Coil/Spark plug connected
Yet to do:
Secure Gear change lever
Adjust front brake
Fit rear brake cabling/adjust
Cover Seat
Fill with petrol!
Slighty closer up..
The seat is tatty, but its just to get it through the MOT.
