Will do! Just got it started tonight after a bit of a saga.. Had to kill it again as it's too late to start it up indoors and it's raining....
Kicked it to death and it would not start, checked the spark, compression was great, it would kinda choke once in a while sorta tempting me to keep kicking.
I even pulled out the wiring and put it back to basic one wire setup (just connect black wire from stator to coil), still would not start. Was sparking well though. Hmmm...
Ended up pulling the carb to clean it in desperation.
Then noticed the damn choke slide was diagonally jammed across the inlet inside the carb!
No wonder it would not start.. Choked to death.
Pulled it apart, added a tiny washer to take up the slop for the sliding lever, reinstalled the choke slide and boom, started first kick
I had set the valves with some figures I got from the monkey bike Facebook group.
It's never started so easily ever before
Somewhat excited to see how it goes!
Hoping to get the wiring loom back in, tidy up the spark plug cable, it's about 3 times the length it should be. Also want to resolder the coil connector as I ghettoed it together to bodge the wiring earlier.
Still got a couple of wires on the loom I have no idea what they do. The wiring diagrams I have seen just don't seem to match up either. I think I have some sort of hybrid harness, or at least one from another year bike confusing me.
Got a rectifier/regulator to see if I can get a battery on there to make the lights more reliable. Just got to work out where in the harness to stick them!
