Hi there
First 8 Pack memory SKU is online:
Team Group Dark Pro "8 Pack Edition" 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit - Black/Grey @ £188.99 inc VAT https://www.overclockers.co.uk/detail/index/sArticle/68110
3200MHz RAM Speed, CAS 14-14-14-31 Timings, 1.20-1.40v VDIMM, Lifetime Warranty with OcUK.
A cooperation between TeamGroup, Gibbo, 8 Pack, Caseking and Overclockers UK brings you this very aesthetically pleasing design with great thermals. But more importantly the IC is Samsung B die and has being qualified and tested thoroughly on the latest Intel Kabylake platforms (Z170/270) and AMD Ryzen mainboards.
With a very aggressive low latency of CAS 14-14-14-31 out the box this kit not only offers tight timings but high frequency as well with 3200MHz. Tested reliably in over 15 AMD Ryzen mainboards with both 350 and 370 chipset at advertised speeds.
Also compatible with the latest Intel Z270 and upcoming chipsets, this 8 Pack edition memory offers great compatibility and incredible levels of performance.
This is the first of many more 8 Pack memory products to come, this kit also offers fantastic overclocking ability where over 4000MHz is achievable on some Intel setups and upto 3600MHz on Ryzen setups with slacker memory timings.
Available exclusivlely only from OcUK, Caseking (Germany) and Globaldata (Portugal) which are all part of the growing empire known as Caseking Group.
Features:
- AMD Ryzen Compatible (350 and 370 chipsets)
- Intel Kabylake, Kabylake-X compatible (Z170/Z270 chipsets)
- Samsung B Die guaranteed
- Tight CAS latencies of 14-14-14-31
- Huge overclocking ability or drop the frequency and go for some CAS10 goodness.
Specification:
- CPU Compatibility: Intel Skylake/Kabylake/Kabylake-X ( LGA 1151 ) & AMD Ryzen 3, 5 & 7
- Chipset: Intel Z170, Intel Z270, AMD 350, AMD 370
- Capacity: 16GB (8GBx2)
- Dual Channel kit: Yes
- Tested Speed: DDR4-3200 MHz (PC4-25600)
- Tested Latency: 14-14-14-31
- Tested Voltage: 1.20V-1.40V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
- Exclusive to Caseking Group
Only £188.99 inc VAT.
ORDER NOW
If your looking for cheap, you won't find it with 8 Pack branding, these memory kits are built with one objective, all out performance and compatibility with the widest selection of mainboards. As such we specify only Samsung B die for our own 8 Pack modules which adds considerable cost, but on the flip side the results is improved performance (tighter timings) and huge OC ability, in our testing we hit 3600MHz on Ryzen mainboards and over 4000MHz on Intel mainboards with these kits. On new Kabylake-X platform expect this kit to yield as high as 4500MHz plus.
This is just the start, we hope by the end of the month to have kits approaching 5000MHz under the 8 Pack branding.
