- 14 Jul 2005
- Birmingham
£299 was the best I found but that was the bay, I didn't want to buy from there.To note a quick google you can find the 5800x3D for £295.
Aye fair enough. I don't mind there if it is sealed and new and they got 1000+ sales and at least 90% positive. Generally all good then tbh.£299 was the best I found but that was the bay, I didn't want to buy from there.
I’d consider a 5950x3d to eke the most out of the platform but I can’t be bothered to go to a 5800x3d from my 5800x - so go to it amd. (Not going to happen alas)
I think he meant that he would have wanted one, then he would have upgraded.There is no 5950x3D on AM4
Anyway - i type this on my new 5800X3D!
Seems to be working, just about to run a benchmark to test it. I think I may want a cooler upgrade. Im using a Alpenfohn matterhorn tower cooler with 120mm fan, maybe time for an AIO.
That's pretty good to be honest.Temp running Cinebench for 10 mins was about 65C, around 40C under no load Windows browsing.
Yeah it was wrong though unfortunately.
Hwinfo was reporting 65c. I then installed all the latest chipset drivers and Ryzen master and that is reporting now about 85c. So I think I should look at an alternative maybe slight undervolting can't do it on mobo though I don't think.
Just checked your mobo bios page:
Update AGESA version to ComboV2PI 1208
If it has 1208 it should be 99% there. All mobos I saw who got that Agesa version has that option.
Poke around in bios.
Hard Reset the bios on the mobo itself.. Sometimes the bios still think you are on the old CPU.
	Alternative options would be 5600 at only £137
5700X at £180
5800X at £230
Just put at all cores, Negative and try 30.
are you running a -30 offset on a 5800x 3d?
how dose the system boost in game
I cant see anything like this in my bios, searched all over. I have the 'AI tweaker' menu, but nothing called anything like what you have there.Something like this:
