Another 120 wouldn't hurt
Pump is ok
Pump is ok
What sort of temp differences are you seeing over the H100 you had in previously? Hopeful I can start with my build this week
Pump is ok
Its fine, I have a rough idea on how the H100 performs as I have a H80, the H100 is roughly 3-6c better. So I knew what you were getting at
Thats still a really healthy drop in temps, especially for that voltage.
Oh and you might have room for a 120 down the bottom next to the PSU.
i say get the gpu on members market and sell your gpu, if the rad wont take it then a quick 120/140/240 in the front would sort it out just move the hdd bay over to the left. It would look mint would also be a lot quieter
Really considering the GPU now and probably get another Rad just to be on the safe side and because I feel the watercooling bug hitting me
DO ITTTTTTTTTTTTTTTTTTTTTT
while you have chance to do it cheap imo its a no brainer
Slightly concerned about ditching my card for one without warranty, that's the only thing planted in back of mind.
Shouldn't be an issues. Most brands/shops are ok with you taking the cooler off, just not officially, if you get what i mean?
but the one in members market hasnt got all the stock parts
