You should easily be able to mount a few HDD's above the psu bungee cord style.
is any one running a 360 rad in the from of their case with a long gfx card?
I'm thinking of putting one in at the front of mine but not sure if it will hit my 7950?
any one got any pics?
On a side note I have one of the 140mm fans at the top of the case, If I do the two thumb screws up tight at the back the case makes a really annoying high pitched buzz. Any one else found this?
Using a xspc AX 360 in the front of mine with a 780 lightning, there is about a 20mm gap between them.
Edit. My fans are on the front, not on the inside.
