- 3 Mar 2008
Here is my i7 680 h100i build
I think corsair really missed a trick with this case. Why no radiator mounting points in the space behind the motherboard tray?
This was something that we have thought about from the very beginning, but then again, the main concept of the case was built around high airflow. So we thought 1 x 240 and 1 x 240/360 rad support would be enough for those who plans to custom water cool their system over air. Still a valid point though, an extra rad mount behind the board would be appealing to some, depending on what the cooling reference is.
Have you seen the back of mine on the previous page?? Couldn't fit another thing in there!
I love the case, just wish it was a little bigger by about 60mm in every direction, oh and i dont like the drive bays, they need to lose the lip inside, had a right job getting my res in. The removable drive cage should be able to be inserted from the outside not the inside.
Can't check what the included fans are but I believe their unique to the case. I've fitted all quiet editions and they rock, they're inaudible and my temps with X fire 280x toxic are still great.
Wondering if anybody here knows which fans are included with the case when purchased? I'm looking for some really high pressure ones and note from the Corsair website that their performance edition is almost double the RPM of the quiet one.
