Got the same rattle and generally not overly impressed with the 540. Returning it for a 750d
I'm happy with mine apart from the fans, would be too late for me to send back anyway (bought it in August).
Read a lot of this thread now and I'm thinking this may well be the case for me. I'm going to be running an SLI set-up, and most likely a H100i too. With that in mind, what sort of fan arrangement would you guys recommend?
Should I switch the 2 140mm fans at the front to 3 120mm fans? And if so, which ones? How about the 140mm exhaust at the rear? I have my eye on a pair of the 1850rpm Gentle Typhoons for the H100i, would they do the trick?
Seems like the CPU will be fine, but I'm slightly worried about the GPUs as in SLI the to one is going to get toasty and this case has no side fan to help alleviate that. How can I set the fans up to 'focus fire' on that area?
Any advice greatly appreciated! BTW the mobo is likely to be a Asus Hero and the cards will probably be EVGA 780s, with the ACX cooler. This is all changeable as I've not ordered anything yet, but will be pulling the trigger next week!
Sure it's got nothing to do with the ambient temps? If you have the central heating on in your house, it could skew the results quite dramatically.
Try the MM? Might get lucky.Dammit i am skint and those stock fans will close £60 to replace! Corsair low noise 120mm in red then lads? Seems a lot of people are doing the same builds 4770k H100i etc. It is what i am doing as well except im on the wall over H100i or H110 with push pull 140mm
agreed, my 540 is arriving tomorrow
