Corsair Carbide Air 540 Builds
Question: Can a 240 ran be fitted at the bottom easily, i.e. if you do not install your HDD/SSD down there, are there holes for some fans etc?
dont think there is tbh, could easily be modded tho, remove the HDD mounts and cut a space for the 240mm rad with a 240mm grill underneath :)
finaly got my block ;) still need to do something with the bottom hole!!
Removed cooling for motherboard as it was kinking between that and cpu, besides it does absolutely nothing.
Looking sweet with that block Nickol, if you get chance would you be able to quickly measure the room you have left in the top left of your rig between the holey bit on the back of the case and the 240rad? looks to me around 23mm but would be awesome if you could confirm it for me, thanks - Adam
now thats an incredible guess, bang on 23mm :cool:
I think one of these might be making it's way to me at christmas, fed up of having my h70 on a length of paracord dangling outside the case!
