- 31 Oct 2011
- Leyland
I've just bought a 540 from off here (used) so will hopefully be building into it this weekend. Is there anything I should know or prepare for? I'm currently running 2x240mm rads a gpu and cpu in a custom loop. Apart from some new tubing for the longer runs to the back of the case will I need anything else?
I'm also thinking of buying some Bitfenix cable extensions just to make sure I have the length and to look a bit better.
Check my build log, im using different rads to you but during my mission i have run into a few issues. It might give you a few ideas.
