That's a hell of a kink in that bottom hose there, hope you sorted that out!
I'd love a 540 case, they are awesome! One day
Looks to be for drainage..
Its a nice case but with a tiny bit more thinking through, better front bays, better SSD cage, etc. it could have been an immense case.
By bay holder do you mean the plastic retention clip thing I called a toggle? it comes off easily which is what I did.
no no mate - that plastic clip thingy is the same is what was in my 650D - they're easy to get out
I mean the actual assembly / cage that holds the whole DVD drives in place.
I've asked this so many times, and i'm gonna ask again, I really don't know if I should do it, or its worth swapping, I keep racking my brains out and I keep umming and arring...
And looking at everyone's stunning examples,
Do I swap my Haf X for this case? I like what you can do with them asthetically, but for me its the performance, will I see much better airflow to my componants then I would with my current case, considering you can pretty much hide the cables much better than the Haf X, and there's no expansion bays to restrict airflow to major componants.
never owned a HAF X so can't coment if your airflow is improved, the 540 is a great little case but for me it has a few flaws which is why i bought a Lian-Li D600, very similar to the 540 but more options and imo a better layout overall. Its one case i shall be sticking with for a long time.
What are the flaws that you picked up?
