nice clean build - where'd you put your Hard disk drive?
Hey everyone, just about finished my first custom build, loved working with the Air540...
- Adam
A quick question, can you use a Corsair H100i with push/pull fans?
Yes. Me and many others do!
Is it just me or are the front cables for power rest hdd light ridiculously short ?? They wont even reach my MB unless i stretch them across it![]()
Right Ive an issue with the hot swap bays. There is a ticking noise coming from one of them. I thought it was the HDD first but when I had it taken out the noise was still there. If i press down on the connection it goes away. Anyone come across this before ?
It's just a cable, it can't be ticking. It sounds like vibration through the case from some other component, a fan perhaps?
- Adam
