Permabanned
There no room at all with mine. Ill show you a pic
I had the lights on a angle where the lights were facing the back where the back fan is. I'll. Be back. Just having dinner. Brb
Hmmm don't see how you could have done that? Need more pictures
Oh and what did you do with the left over cable?
I've got 3 monitors too. Not that pleased with them though as they don't have display ports, which means I need dual link DVI cables. AMD however don't like DVI cables and seem to assume that everyone has DisplayPort monitors. So it'd cost me £150+ in adaptors if I went with AMD cards (which I'd sort of like to do). My monitors only cost £150-ish!
They also don't really do 3D with Nvidia cards.
That's the other thing with this case though, I've got mine tucked away under the desk, but if you had it on the desk you'd need to have a big desk to fit 3 monitors too. The 540 has a bigger than normal footprint, although I'd be surprised if the extra width was the deciding factor when deciding on 3 monitors.
Also, I found I don't like gaming on 3 monitors, everything is too stretched.
Hello again. I started from the right bottom and went left all away around the case and was back where I started and had 30 or so cm left and put that in where I started on the bottom right side in the front area. I can't see it,but does light up well. Have you tried to take off fan then put light's up. Put fan back and see if it fits?
The led cable goes over the screw holes so impossible.
Done it. Just had to take fan and put it behind. Not ideal but only way. Chuffed with the rear. The controller fits in great in the bays!
[/QUOTE
Nice one
Yeah I love the controller. I can change colours that fits my mood. I love the hue it was worth getting.
And how quiet is it with that setup ?
Why did Corsair go with a removable rear 120mm fan grill? This makes it difficult to use rubber fan mounts.
This is how it is for now (awaiting res and may re-add vga block). I did have the gpu watercooled in my old case but am unsure if I will keep or sell the card for now.
My old acrylic res is also a bit on the battered side and I intend to replace it soon. The res would be placed where the black 90deg fitting currently sits in the bottom left and would incorporate the drain port. Incidentally I got to relive my hate for T lines in this build.
Got a few more pics so may create a mini buildlog later when I get around to it (loads of photos but going through them quickly not actually the ones I wanted!)
