I have absolutely no idea why you keep posting 'prime' shots where the system is running cooler than the maximum recorded temperature.
I have no idea why you are so defensive about all this. All anyone (including me) is pointing out is that you are making claims that are not backed up by the evidence pictured.
And if I'm so wrong how come CPUz and RealTemp are suddenly saying the same thing?
There is still something odd about these readings.
You are not listening...
when you turn off LLC, you are no longer forcing a constant voltage to the cpu, thus the voltage will vary depending on load. Prime does not give 100% load all the time, it also differs, hovering around 95%-99%. When the processor draws current it also produces heat if this the voltage is variable so is the temp produced. this is why 68c is shown when I snipped the shot. the temp never rose above 72c during the 10mins, but the temp was around 68c-70c most of that time.
What is wrong with the evidence, you can see plainly what is running, how long its been running, what the idle and max temps are.
To be honest I couldnt care less, I just dont suffer fools gladly thats all.
And Bradley as I said originally the temp difference is not worth worring about, its a couple of degrees if that. I dont want to enable LLC on my system due to the risk of voltage spikes. I was just giving my opinion thats all, and to be honest didnt expect to get slagged off for it.
The reason I changed from the fenrir to megahalems was temperature and the difference was about 10c under load, the reason I changed from the megahalems to the Corsair was due to room and less weight stress on the Mobo. I want to increase to 12GB soon and needed to get to the dimm socket that was inaccessable with the megahalems.
Bulldog could probably do a specific test as I think he has both the Megahalems and the Corsair.
I see from your Sig that your running 4.2 at 1.23v, so I dont think you have much to worry about. I have an IBT vhigh 16thread 10 pass test on 4.2OC with the H50 if your interested. Temps maxed out at 80c with a 32c case temp. I'm sure someone with pick this to pieces too. but it will give you an idea.
