Those temps are amazing Jon!
I can't wait to get my chip under water, I should be getting my Aqua Computer triple rad this week hopefully, then I will be getting my HK3 block the following week, then I will be ready to start building my loop.
I have been getting a little worried though, after seeing the results some of these guys have been getting with this H50, as I would hate to have spent all of this money on my WC bits to find out that I have worse temps than these guys get with a £60 cooler, but after seeing your post here it has made me feel better about it all.
If I can have temps below 70c with my chip at 4GHz I will be a happy man.
I might try and see if I can get the double and triple rads into my loop, but I think this will prove to be difficult inside my case.
I've been playing around with my chip trying to get it stable @ 4GHz using 200x20 with LLC disabled, and I have finally managed it, I had to set Vcore to 1.315v in the BIOS, but in CPUZ it sits at 1.248v under load, I have Vtt set to 1.335v as well, I am going to continue tinkering with voltages to see if I can get them any lower though.
I don't know if I am going to bother getting one of these units now for the missus, because a TRUE with 2 fans fitted is almost as good as one of these anyway, so I would just be wasting my money if I did buy her one..
They are definitely nice little coolers, and they do a good job also, but as I said, they only seem to be a few c cooler than a TRUE, and both Gaidin and bulldog are running much lower Vcore and Vtt than I do, so I recon if my chips could do 4GHz with the voltages they are using, the temps would be pretty close anyway.
