OcUK are advertising these as having static pressure of 26.4mm H2O... whereas on the box it's 2.64mm H2O
This was noted when they first came out. Suprised Ocuk have not changed it yet.
Damn shame they didn't as I doubt I would have bought them if not for that - I have left a remark in the Cust Service forum asking that they do amend the description.
Hmm, all this talk of high static pressure fans... I succumbed and have today taken delivery of a couple of Akasa Apache's to swap out with my Noctua P12's that I'm currently using.
Anyone else with these Apache's read the back of the box they come in?
OcUK are advertising these as having static pressure of 26.4mm H2O... whereas on the box it's 2.64mm H2O!
Still an improvement over my Noctua's but that slippery little decimal point makes quite some difference - suddenly it doesn't seem like a worthwhile upgrade after all.
Anyone else made the same swap? Should I use them or send them back?
Noticed this my self today while reading the back of the fan box,anybody know if Scythe S-Flex F 1600 RPM would have higher static pressure than tha Akasa's? can't seem to find any details anywhere.
As far as I can remeber reading reviews. The Apaches are top for H20 pressure..
So they are better than the scythes and Noctuas. (not be a great deal if I remeber, but still better)
Anybody got one of these in an Antec P180?
any problems fitting it or any pics ?
I have them in a P182 and no issues fitting them if this is any use to you guys.Would love to know if anyone has one in an ANTEC 300.
Sorry all i have is this bad one.afaik the P182 is pretty similar to the 180 so it sounds promising
do you have any pics of it?
Ive yet to try the apaches, they sound interesting, pity about the colour. Ive tried scythes and noctuas, the scythes were ok, whereas i found the noctuas to be seriously over rated, i personally prefer sharkoon fans, the build quality is fantastic, they shift a lot of air and they look good.As far as I can remeber reading reviews. The Apaches are top for H20 pressure..
I find the Apaches terrible to look at in my rig and the noctua less offensive.I don't mind the color of the Apaches tbh, they are a hell of a lot better looking than Noctua's color scheme, they look really tacky imo.
