How long have OCUK been out of stock of the Corsair H50? Any word on when new stock wil arrive?
I was looking to grab one of these as well, as the Fenrir is not performing adequately (even after reinstall). I've ordered the rest of the parts I was after but now I'm waiting on this to come back in stock. Another site has them listed as out of stock but arriving September 30th, which is longer than I'd like to wait. I need it pretty promptly - before the end of the month - and I'd rather order from OCUK if possible. I don't want to place an order without knowing when it's due.How long have OCUK been out of stock of the Corsair H50? Any word on when new stock wil arrive?
Well I currently have my RAM at 1.640, would it better if I run it at 1.5 then?
If you can keep the system stable at 1.5v, yes - but it's fine at 1.64 as it's within spec (but lower voltages are always a bonus).
If you want to try it - drop it to 1.5v then run memtest, prime95 and then use and abuse in everyday usage - if it gets through that little lot and you're not experiencing any problems then keep it at 1.5v.
If it fails any of the above, up it incrementaly until it becomes stable - hopefully you'll not end up back where you started at 1.64v![]()
dont u have to pay for memtest?
i have found that you may already have these screws lying around if you have recently bought a new case...while installing my hardware i found a load of screws in the haf box that had wheels in it also for base well some of screws fitted the rad perfectly so check the bag of screws for simular thread and size you may get lucky
different subject ...gaiden could you recommend any i7 noob guides as im looking to get between 3.8-4 from my 920 D0 using this H5O and this build will be my first upgrade since 2006 (939) which im typing on nowx2 4800
used be fast
cheers m8,
HRhino"
Sorry to be a noob but can someone explain push/pull?
