I, personally, would choose the apaches - great value for the dB/performance.
If you just painted the outer casing i don't see a problem - unless you had big runs.
I suspect painting the actual fans would have a ‘slight’ performance trade off - it would largely depend on your skill. My main concern would be noise - as an uneven finish would probably negate its quietness.
Someone’s bound to have tried this – it may be worth a separate thread to get some opinions.
