I have little first hand experience but seem to recall using all 6 sockets is a real pita when OC. Do you need all that RAM. As for when you have 6gb installed free memory will not be anywhere near this. Presumably your using 64bit OS but your gfx cards will be 'stealing' system memory nevermind the OS etc being loaded in it.
I've just lent my spare 6gb to a friend who has a asus p6t deluxe v1. He's using this with his kingston 6gb (both 1333mhz stock) with no problems. Board / Kingston RAM / cpu were supplied pre overclocked.
If your set on a new board try the foxconn bloodrage gti, I have the full fat version and it's fantastic. Only 3 dimm slots though, for me 6gb is plenty until 4gb dimms are affordable.
hi m8, thanks for the info, but as mentioned
bios isnt detecting full amount and bootup before bios freezes if i try even one dimm in either first 2 sockets which your supposed to do if having memory issues and wish to check if the ram works but in this case the socket dont work
.....but anyway the other 4 are working fine with all the memory tried individually and together and i even memtested in pairs and quad sticks in windows.
as to the memory controller and overclocking...the i7 controller is in no way the same as the 775 or before it... its reported and tested as better than the previous generation controllers and will work past 1600MHz in rigs in T1 succesfully
i wasnt after major o/c anyways just around 3.4 with turbo and the 12gb i bought as i do photowork and some minor video encoding/editing so it helps a great deal in the speed on that.before the dimm socket failure i did try taking 6gb out and there was a noticable speed drop and anyway i got the memory at a good price around £120 (new) for 12gb now its around £260
heres an example of how good the i7 memory controller is when running corsair memory :
"Running 12GB of memory on an Intel Core i7 platform can be done and it is easy to do at that. The sweet spot for running 12GB of memory was found to be at 1600MHz with CL8 timings. Overclocking was possible and was also easy to do with no voltage increase required. Stability was also not an issue as Prime 95 and gaming were done on the system for hours and hours with no ill effects. If you want to run 12GB of memory you have nothing stopping you from doing so."
http://www.legitreviews.com/article/879/1/
i did look at the gti but i wouldnt be able to use the pci-e physx and asus soundcard on it
and id have to sell some of the memory.
so the ud5 will be okay as its identical to the extreme which is a very good board in my opinion although the evga classified looked interesting untill i found out the bios is extremely complicated aimed at people using pelter and nitro
and theres a slight lag due to the added pci-e chipset so thats off the list.
anyways ill retry the H50 and follow the installation manual to the T (which im sure i did
) and use the thermal compound method both bulldog and gaiden used (i never in my mind thought it would be okay due to air bubbles which is why i used the line and rice method) which is to apply a thin coat on the H50 heatsink and a bb sized blob on the cpu. then ill see where i get to
thanks to all for the help and kind advice.
regards,
HRhino"
