you bought it from ocuk so talk to them... IT returns conffose the hell outta me tbh. How old is it?
Anything that uses mis-matched fans (speed or air pressure) is very unlikely to work well.
You want two matched fans that are both running at the same speed.
One reason the Apaches work so well in push/pull combinations is that they are PWM and you can drive two off the CPU fan header with an Akasa PWM splitter cable. That gives near silence at idle and they ramp up together when the CPU temperature picks up.
I haven't read this thread for a good month now so am a bit behind, I've had my h50 for six weeks with 2 apache fans fitted in pull/push config. Back 6 weeks ago people where suggesting having the fans setup blowing into the case, now it seems this theory has changed and now people say have the fans exhausting out the back on the case (as recommended by Corsair), people who have changed the airflow, has there been a marked improvement??
Do H50 owners still have the block positioned upside down on the CPU, so the writing is upside, as this was also recommend awhile back, just wondered if this was still the case??
Looking forward to trying the H50 in my p182 this weekend, gonna try and use it as an exhaust too at first
Are the Akasa Apache fans good ones to use in a Push/Pull config for the H50?
How did the install go? I am looking at installing one a P183 soon.
Just ordered but had to order 25 - need 4
If anyone else off here wants some i will have plenty spare when they arrive - contact me via here
They are 6/32 unc socket caps and are black and 1 1/2" long
Supplied ones by corsair are 1 1/4 " and not socket caps
Postage will be tiny
Have you got any left mate?
The one with the newer mounting system is a bit of an annoyance to install compared to the older one with the thicker screws.
