- 6 Sep 2005
Hi everyone, I wonder if I could ask your installation advice with the H50.
I've had mine for a couple of months and I commented in another thread that it's great, apart from the fan is very loud and can't be turned down due to having to have the fan controllers switched off and leaving it running full pelt.
It seems that's not definitely the case so I'm looking for a bit of clarity please.
Currently the pump is plugged into the 'system fan 3' and the fan is connected to the CPU fan.
The motherboard is a Gigabyte EX-UD5.
The case is an Antec 1200.
Fan speed control has been switched off in the BIOS so it's running at full speed and making rather a noise at the moment.
The CPU is ann I7 920 at stock, core temp shows the temperatures between 25-29c when not under load, then stressed they are around 40c.
Thank you in advance for any thoughts!
I'd like to check that it's been installed and setup correctly. Could any settings be changed to make it quieter?
I would be quite happy to replace the fan with another model if anyone could suggest one that would do the business as silently as possible.
How easy is it to install another fan? The screws go through the radiator and fan into the case to attach it, will 'normal' fans allow you to put the screws through them? We were going to put the Antec case fan on instead as it is near silent but the holes weren't in the right places.
Many thanks
Many thanks
