One added problem is that i have 2 5870 in crossfire making the inside of my case a little hotter than most people, even though i have 4 (120mm) case fans besides the 2 on the H50 radiator.
If i put the H50 in an intake position (to draw fresh air inside the radiator), my case will be even more heated up. If i put the fans in an exhaust position the CPU temps are actualy 1-2º lower, and my case is a little cooler.
But, as i said, no matter how i put the fans in the H50 radiator, Qfan disabled/enabled, AS5 thermal paste included, 100% sure the pump is properly fixed in the socket (yes i'm sure
), my load temps are always around 80º.
Yes i have an overclocked I7 with HT, but i've seen a lot of reviews around with the H50 reaching 65-70 on a similar system, wich i find realy odd.
