- 6 Sep 2016
Don't bother with that sub it's crap. It the extra £200 into speakers/amp get sub later
Skip the sub for now put the money from sub into speakers/amp
please could you recommend speakers and a amp. there so much out there, There either cheap crappy ones or to expensive.Skip the sub for now put the money from sub into speakers/amp
QA 3070s subwoofer is no good anyway, not unless you get an amplifier that has sub out or pre out, which the Marantz 5005 doesn't. You'd have to spend a bit more on an amp to get sub or pre out
Even so, I wouldn't buy the 3070s regardless, not when the BK Gemini II is only a few more £.
QA 3020i are a good speakers, but if you have a Richer Sounds store near you, then you can get the 3020 for a paltry £100. I very much doubt the 3020i model is worth the extra £150.
If you are looking to spend £250 on the speakers, I'd probably be more inclined to spend a bit extra and go for maybe Monitor Audio Bronze 2 or if slightly larger speaker is not an issue; DALI Zensor 3; otherwise for £100 the 3020 are a fantastic bargain (if you can get to a Richer Sounds store).
Bronze 2 and Zensor 3 have larger woofers, so as Ivan has said above; you may feel a subwoofer is not needed.
Of course if you do have a local Richer Sounds store, you should be able to demo all these.
For the amp: Marantz 5005 is a decent budget amp, but something like the Yamaha AS501 for £250 might be a good choice. Has dedicated subwoofer output (so no need to mess around using speaker level cables from amp to sub) and a built in DAC. If you've not got a sound card, saves connecting the amp to the onboard audio.
I should have pointed out that you can only get the Gemini II subwoofer direct from BK Electronics themselves, but if you can listen to some speakers at somewhere like Richer Sounds, then you can at least get an idea whether you'll want to get a subwoofer as well, or maybe at a later time.
So if I go for a Dali Zensor 3 speaker and Yamaha A-S501 Integrated Amplifier. Go for a sub later that would be a good choice?
I like the marantz amp but none seem to take a subwoofer.Sound good choices to me.
ummm what's your opinion on the Dali Zensor 3. if am asking too many questions just say.I use ruark etudes don't feel the need for a sub for music . Only for movies and or music in larger room
The only ones I have experience with is the Kef Q100 they sound beautiful but they discontinued those..Never heard them. Have owned kef, celestion, wharfedale, b&w, ruark speakers. Svs, Yamaha, rel subs
