Thanks for the kind words guys, and also a huuuge thank you to Plec for being with me throughout this whole thread.
You kept me from losing my mind over this problem, and I can't thank you enough for this my friend!
About the new CPU, it just doesn't want to go any further than 3.8GHz no matter what I do.
There is something quite not right about this chip, I have tested it with 4 different coolers (stock, 2 TRUE's, and my Zalman) and with every single cooler the idle temps at stock are sitting at 53c, and it shoots up to 80c under load, now my previous chip would idle at 34c, and hit 61c under load, so as you can see there is something not right with it.
I have used up half a tube of AS5 from reapplying paste and reseating my coolers just incase it was a bad mount that was causing this, but nothing I do makes a blind bit of difference to these temps.
To begin with I'd suspected that the IHS was warped and wasn't making a proper contact with the base of my heatsinks, but I checked it with a straight edge and it looks fine to me, but someone else on XS mentioned something about it being a leaky CPU, I don't fully understand what he meant, but for those who are interested they can read the post
here.
I have it @ 3.8GHz with only 1.216v Vcore and 1.280v QPI, so the temps shouldn't be as high as what they are.
My last chip idled @ 46c when it was clocked to 4GHz using 1.264v Vcore and 1.355v QPI, and it would hit 84c under load, but this chip at 3.8v has the exact same idle temp as it does at stock frequency, but it hits 92c under full load with a TRUE with push/pull fans!!
And like I said, it isn't a bad mount because I have tested 4 different coolers, and each one gives me roughly the same temps.
Anyway, I will be picking up another chip in the next couple of weeks for my 2nd build, so heres hoping I get a nice one.
Thanks again for the kind words guys.
Oh, almost forgot, @ mothermachine, do you know the batch number of your chip?
It will be on the box it came in, if you don't have the box anymore, it is also written on the IHS, my one is 3910A***, maybe your chip has the same problem as this one I have, the temps are ridiculous, and especially when I compare them to the temps of my previous chip.
