It only seems to be IntelBurnTest that is causing the problems.. I am testing with OCCT atm, and it runs without an issue, same as Prime95...
I haven't used memtest recently, the last time I used it, it ran for over 3 hours, but when I came back to check on it, my PC had froze, and the bottom half of the screen was all corrupted...
But when I ran it with only one module installed it went the entire night without any errors...
Would you class 3 hours of memtest without any errors stable??
I only run it for a few hours - but some forum members will say to loop it for at least 8 hrs. I personally would run yours for at least 4+ hrs
However, the fact that it froze with 3 sticks but passed with 1 (did you try all sticks independently and in different slots) may point, again, to a combination of BIOS settings that are not compatible. The fact that you've managed to get your system almost to the point of stable makes me think that you may be one setting away from finally sorting this problem.
I would leave IntelBurnTest and just concentrate on getting the 3 sticks stable in memtest - if you manage this i would suspect that you would get the results you want in the Intel one.
Having said all that, i will end with what i said earlier: IntelBurnTest is very aggressive and none of your games and applications will even come close to achieving the amount of stress that this app applies to the cpu. So, even if there was a slight 'BIOS-setting-problem' the likely hood of it manifesting in day to day usage would be negligible.
I mention this again as you could just relax with your build for while until your psu arrives - because if that does, by some miracle, resolve the rest of your problems you're going to kick yourself stupid for putting yourslef through all this stress.
And also when I look at the graphs it creates at the end of the test, the graph for the 12v shows some really weird inconsistencies...
Check out this graph to see what I mean:
Surely this can't be correct?
Hopefully the new psu will resolve this - it wouldn't be that surprising if it turns out that you had 2 underlying problems: a BIOS that needs nursing and a flakey PSU.
) reminded me that we hadn’t fully abused your PSU.
