Damaged 3080fe rear cap (with a cracking ending)
Bit of vague rights quoting and hypothetical pondering. I only did the back as it seemed adequate to keep temperatures just under 100 but with summer coming I'm thinking ill probably have to do the other side which I'm not keen on.
Did they want to see your receipt from the retailer?
It arrived in their Hong Kong centre two days ago. Should have an update mid next week.
@Dannysaiyan I had identical mining temps when I put the plate back on so I don't think they were useless (some may argue that because they're so bad they are useless in the first place).
How long after arriving with them did they take to turn it around and you get notification that a replacement has been sent out? Mine arrived with them early this morning.
They did want the invoice yes.
2/3 days. Was a quick turnaround. The shipping for me had the county as Belfast which was weird but it turned out fine.
I wonder if you could have RMA'ed it with the FE retailer. And if so... would that be quicker? OR worse ... you get a refund as they have no stock :|
Thats a shame. Be nice if they kept some stock by for faster RMA turn arounds.
Hope I never need to RMA :| Been more than 10 years since I had a GPU fail on me.
I never had a GPU die on me ever not even shunt modded ones but then I always have them watercooled running nice and cool.
On the other hand 2 out of my 3 Nvidia laptops died on me with GPU failure but they were running hot.
Trying to keep my current one running as cool as possible and so far so good and it outlasted my previous ones already.
