- 21 Jul 2005
- Officially least sunny location -Ronskistats
I would say it was either done in transit or the component had a defect all along (wasn't spotted by QA).
For anyone unsure about warranty, it doesn't overide the law. Burden is on Nvidia to prove the user broke it, in the UK we have 6 years by law to return a broken item according to the consumer rights act, companies can offer repair or replacement but they cannot deny it via terms and conditions, if said item is suspected to be broken.
Never considered that as a thing. From a cursory google it seems that this type isn't prone to cracking from high temps (it's the smaller MLCCs that do). Not saying it's not possible but just not highly reported.
@0h_no_not_again have you anything to say on this? You seemed to know your caps quite a lot from your reply.
Worth saying my prior guess on the exact component was slightly off previously. Assumed it was an input cap on the VRM, but it is definitely on the output side, i.e. much lower voltage.
I believe the part is a Panasonic EEFSR0D221R4
220uF, 2V, Polymer Aluminium.
Note that it is a 105C rated part. Higher than 105C won't kill it instantly, but the lifespan will reduce from 2000 hours @105C to 500 hours @ 115C or 250 hours at 120C (based on industry standard guesswork)
Cracking jokeDo you doff ones cap to him? **baddumm tsst**
The thing that cracked should be able to handle 120c+
So if you were mining constantly without being too concerned with temps, you could quite conceivably only get 2000 hours out of it, which is less than 3 months?
The other thing to consider is down time. If you arrange a repair at an tv repair shop you should only be without your card for a couple of hours. Return your card and it will be at least a day each way and a day to fix it.
Rma seems to be going forward.
Basically stated that I felt I was being punished for being honest and that I could have easily been dishonest in sorting the rma.
I thought it was well established that things like warranty seals aren't legally enforceable.
