Having a nightmare of a new build - short version is that the NVMe, once in the case, will not install windows but outside of the case it's fine (also, i can install windows on a standard SATA SSD inside the case)
After comprehensive troubleshooting/bread boarding (i have 3 computers to borrow from) - i'm leaning towards the Dark Rock 4 applying too much pressure around the socket and interfering with the operation of the NMVe when screwed into case. i.e. due to forcing the MB to level out - but there's no visible warping of the MB - but there will be forces around the socket given fitting and right next to NVMe slot.
I've fitted a couple before but i'm now second guessing myself about the starting gap between the retaining bar and the socket bracket. Re-assure me that this the standard gap before tightening the bar to meet the bracket?
Link (can click on pic to zoom in):
https://imgur.com/75LJZvl
I'm in the process of loosening brackets ever so slightly and will tighten to bar to bracket once again - finger tight. But would like my niggle stomped on...
Spec:
MSI B450 Tom MAX
3700X
3600MHz Crucial memory (not clocked)
Dark Rock 4
1Tb WD NVMe
2 x Crucial 1TB SATA - have not been attached.
GTX 1070 (from old build)
Antec HCG 850W (excessive but bargain in fire sale - less than year old)
bequiet Pure Base 500 case
@doyll - would appreciate your experienced eye on the above linked image if you have the time and hands on experience with DR 4.
Spec:
MSI B450 Tom MAX
3700X
Dark Rock 4
1Tb WD NVMe
