Yes, they are - but usual cut outs and indentations throughout. But is still under suspicion...Maybe it's case causing distortion, not cooler mount .. assuming that is cause which I doubt. Is case motherboard panel and standoffs on one plane? If they are not then they may be stressing the motherboard so it isn't flat.
I've replaced middle unthreaded standoff/riser (spacer) with a threaded one - the one near NVMe drive - so I will be able to secure that properly. I'm hoping that screwing down this area will level out any bowing that only having outer screws may introduce/exacerbate in the middle of the board (my logic anyway).
Also, refitted case back-plate - still looks awkward - but as mentioned before, pretty standard fair.
Will do - i'm looking harder at the case - but still feel it's a combo of cooler and case fixing.Plase keep us posted. Really curious to know what the problem is.![]()
If this fails - i'll try stock cooler, but don't fancy it's chances of survival if it fails again as i haven't really got the time to be troubleshooting such a whimsical issue. I normally isolate the core of the problem within an hour (if hardware and standard build) - this is starting to grate, as could be a combo of factors...
Sod it, i'll take an 30 minutes in hour and get it in the case, before i lose daylight. Bare bones setup - and see what happens. Won't know conclusively until after a couple of days and multiple restarts even if it passes a few restarts at the beginning.
JOY!
