I bet it will. For me it's now about the pixel density, at least for productivity.
I find it hard to use standard 109ppi desktop screens for reading and writing.
Once you use a high DPI screen on a daily basis it's very had to go back.
Most PC monitors are typically only about 109 ppi (pixels per inch), where each pixel is quite visible if you're doing normal desktop work.
For example a 27" WQHD at 2560x1440 is only 109 ppi
The retina screens in the Apple Laptops are 227 ppi, which is gorgeous for text, similar for the phones too.
This 32" 8k monitor is 280 ppi
If you type a screen resolution in here, you can adjust the screensize to see what pixel density you get.
https://www.sven.de/dpi/
A 4k monitor would need to be 20" to hit 220 ppi
At 27" it drops to 160 ppi
At 30" it drops to 147
At 32" it drops to 137
If I'm going for 2x pixel density from the standard 109 then a 27" 5K would be perfect at 217 ppi.
Or if the next jump is up to 8K then 32" is pretty good at 280ppi.
The monitor itself is getting big then though, so I'd probably prefer to have 8K 34" at 260 ppi - but have it curved. You really need it curved once you get to 32"+
I had a 40" flat 4k Philips monitor for a few months and it was awful. Way too big so I sold it.
So, my two ideal next monitors could be either of the following:
- 27" 5k at 217 ppi, with a high refresh rate
- 34" 8k at 260 ppi, curved, with a high refresh rate.
I reckon 34" 8k 260ppi curved monitors (or maybe 38") would be big sellers if they can hit the £1k price point in the next few years.
