Diablo 3 (Console versions)
The stuff with int and stuff on should be the things that have Scoundrel/Enchatress/Templar Relic on them where it normally says the weapon type (just under the name I think on console).
To expand stash it should tell you somewhere around the bottom left quarter of the screen when in your stash iirc (I don't actually own the console version, just play once a week around someone elses, so going from vague memory :p).
I don't think it does as I've been on the enchantress but it doesn't come up :(
I started a HC toon to get the trophy, opened my game up around L30 and a guy kept joining then disconnecting when anything above a blue popped :rolleyes:
Closed the game off in the end.
I'm pretty sure they've said they have no intention (currently) of introducing seasons on consoles. Most of the other stuff from 2.1 should be introduced at some point, though.
Edit: No leaderboards either afaik.
Hey guys, got this last week for the ps4, loving it so far, never played a Diablo game before.
Any newbie tips or tricks?
Im struggling to get rid of old items so im hoarding a bit, Are there any items you should keep? or is it safe to just salvage all your unused items?
Level 17 Monk so far...
Yea most rare items you can salvage without to much thought unless it can be an upgrade with enchanting. I wouldn't worry to much until you hit 70 about items because you will change them for better ones every level almost.
Salvaging is massively important at 70 because you will need the materials for enchanting it's bloody expensive.
At level 70 it's worth keeping hold of some legendary with unique abilities on them if you think there is a build you could use it for, but forgotten souls from salvage are also important for enchanting your other legendary
Thanks for that, just the advice i needed. :)
I got a green set, the captains something. There are only 3 parts to the set and although it has dropped some of my stats, the perks are very good. Still needing a new weapon, had the same one BG gave me ages ago. Socketed with the royal emerald = 130% crit damage yo
