Personally i think B grade is fine in a home battery, especially if you DIY build since you can replace modules as needed. From what i've seen a lot of the factors ultimately pertain to how hard you can push your cells (ie they failed various metrics that make them unsuitable for high charge/discharge in EV's). Although different manufacturers, I think fog stars lists the B grade 280Ah at 0.5C charge/discharge and the A grade at 0.5C charge and 1C discharge. Typically what i've seen around other sites/aliexpress/alibaba is A grade should be capable of closer to the 1C and lower grades tend to be set at half to be safe.
Also supposedly the MD of fogstar uses B grade for his stuff so it can't be all doom and gloom.
