The best way to check would be to remove the top card and just run the other two and see what happens?
Time to upgrade to Photobucket Pro!Really don't know what to suggest about the trifire being a funny git but I just seen on another mod how to remove the paint from corsair ram, I thought it was anodised but looks like they are painted.
Remove the red bits at the top, paint stripper applied with paint brush, wire brush to help get it off, paint wise I would do an ultra light coat of primer like 1 quick pass & do a light but thorough coat of colour of choice or leave bare metal, avoid metallic paint as it needs a coat of clear laquer.
It's what I would do personally if I had that ram & wanted a different colour.
Bandwidth exceeded OCD-OCTime to upgrade to Photobucket Pro!
Glad you got it sorted, asked AnG3L who I got the tip from if it was paint or anodise & it's neither, they are powder coated to my surprise, but still the method I said about is what he used for removing the colour so he can leave them as bare metal or colour them
That's what I'm using. I can refer you if you want
(Gets me some extra storage space
)I am SO not renaming it Project POM-POM ! ... but thanks .. I'm looking at this PC in a whole new way now lol
