Dremel Dream Machine!
Do you have an electronics store that sound like a holiday camp made popular in a BBC sitcom starring Ruth Madoc? They sell aerosol based IPA. Not cheap mind.
Quick trip to the Hi-De-Hi shop me thinks.
Just about to WC my set up and this has scared the bejesus out of me.
OCD-OC. We feel your pain. Best of luck with it.
If it's of any use to you I've got an 8800 GT 512 you're quite welcome to borrow in the meantime.
I dont think it does have castor oil in it, but im sure it would say on the bottle
Edit: just found some do have castor oil in them, it all depends which one you buy.
found IPA swabs from the pharmacy, worked a treat to clean it.
BUT
the main card that got dripped on (the top one) works ... even ran furmark
now the other 2 that were X-fired don't show in device manager ..
I stripped them all and cleaned and reapplied thermal paste etc..
so now I have no clue what to try
whats really weird is they show temps in GPU-z !¬
just don't show in device manager or in CCC ... Grrrrrr... back to the drawing board
I fixed the damn leak at least :P
i know its a PITA but the only thing i can think of is running each card on its own , just to rule out if theres a bad one.
as someone has already said, it may well be worth investing in those full cover plates with £1000 worth of gpu to look after.
...wish id remembered to fit a drain line :o
gutted for ya mate, but keep us updated wont ya.
lol yup ... i did a certain amount of that when it was finished .. no denying it :P
but I usually clean up after meself ... this however is a vexing residue of some concern and no doubt !
I guess I have to strip it down again and see if I've shorted the cards with the waterblocks or somethin
With a reference 5870 you need to use the stock ati backplate, ek do their own in nickel or black finish, there is also a v2 backplate for version 2 cards. I used the nickel on mine. Did try to see if yours are reference or not.
http://forums.overclockers.co.uk/showpost.php?p=17136800&postcount=80
gotta try and ressurrect 2 x 5870s before I buy anything :p wish me luck
We will have these instock later this week :P
Also got your email about Dominator heatsinks. We don't have any spare heatsinks around sorry my friend.
no worries, .. thanks for looking :)
Hope those 5870's come back to life, gutting whewn something like this happens but you seem to have taken it well, all in the name of science :)
