Ok from my sig you can see my specs. I'm going to uni soon so can't take a big TV with me so I'm going to get the Panasonic TX23LXD60 LCD TV.
Now the problem is that it doesn't have a DVI/VGA connection.
I have seen about the web these DVI to HDMI cables.
Now my question is; Will I loose quality or have any problems (e.g ghosting, washed-out clours) by connecting the DVi to HDMI cable to my TV from my X1900XTX as long as I have the fgraphics card set to 720P output.
Has anyone tried this?
Thanks in advance.
Edit - perhaps this is in the wrong forum, maybe it should be in monitors, I don't know.
Thanks in advance.
You can't have the native res because hdmi is designed for hdtv signals not pc signals. They can only take 1280x720@60hz (720p) or 1920x1080@30hz (1080i). The only exception is some LG tv's which can take the full range of pc reses over hdmi.
