ugly ferret said:Yeah though you don't really need it, just set the res to 1280x720 in display manager.
And then would be how it should?
OzyOly said:But do they have DVB tuners?
Danzla said:no but thier reviews state that the freeview is good quality
ugly ferret said:lol, a 23 inch tv won't have a 1920x1080 panel, I can guarentee that. The smallest 1080 panel tv you can get is 37 inch.
Danzla said:monitor that isnt a tv buddy![]()
They don't have a DVB tuner yet they have freeview?
ugly ferret said:I don't get it then, why do you want such a small tv with such a high res? You won't be able to see any difference between 720p and 1080p at normal tv viewing distances, only if you sit right in front of it like you would with a monitor, in which case why not just get a monitor and a tv card for your pc.
They're never going to make 1920x1080 tv's less than 37 inch because there isn't any demand for them in the tv market. Some people say 37 inch is too small for 1080p to see any real benefit.
They will have freeview models and non freeview models, just double check the specs when you buy it.
Personally I don't rate the samsungs at all, I think the freeview picture is very blocky and HD looks very noisey compared to other sets. But as said already, they've had very good reviews so I suppose it's a matter of personal taste. You're best off going to a shop and seeing them in action for yourself and deciding which picture quality you like the best. Double check here to see if it can support native res over vga, though I'll give you a list of ones that do and don't:
Support 1360x768 over vga -
Sony s2010/s2030 series
LG LC2 (over hdmi too)
Samsung R74 series/R41 series
JVC DX7 series
Philips TV's with DVI input
Dell TV's
Older toshiba sets
Support only 1024x768 over vga -
Sharp tv's
Philips tv's without DVI input
Toshiba WL66/WLT66
These are all the ones that I know for certain, if a TV's not listed then it may or may not support native res over vga.
ugly ferret said:I'm pretty sure. I've just been looking at the maual and it says "the hdmi input terminal is not designed to be used with computers" and also "The HDMI IN terminal can only be used with 480i, 480p, 576i, 576p, 720p or 1080i picture signals". So that pretty much confirms it.
What about the sony and the LG? Have a look at them, they're pretty good. The LG especially as it can do 1360x768 over hdmi as well as vga. The LG is very good with HD pictures as well, I think in curreys and comet superstores they usually have them displaying HD material and it looks amazing. I've seen the 26 inch version for 465 pounds which is pretty good. There's a 23 inch LC1 version for 400 pounds as well but I'm not sure if it has the same specs and it's not much cheaper really.
glen8 said:Mine works fine but I have a Toshiba not a Samsung
JAKUS said:What model Toshiba ?...they are 1900x1080 but will not take a 1080 progressive input for 1.1 pixel mapping, Well that was the case up to about 1 month ago as I was looking at getting one. Just clarify that for me would You, Cheers
glen8 said:My toshiba (66 model) takes a 1080i input over the HDMI 1:1
My graphics cards needs to be set to 1920x1080 for it to work. The image quality on windows desktop, games and movies (xvid, hd etc etc) all look as good as on my dell 20" TFT
LCDs are progressive in nature, it's the input which can't accept 1080p input. This means that rather than the source doing the progressive scan it's left down to the TV.
as stated above, tosh 68, samsung, sony w/x, sharp now accept a 1080p input
