Eggenberg4Ever said:Using 3D Mark 05 I get a score of 5699
its not the greatest score, but not bad either (stock score is about 4000) try lowering the memory a little and pushing the GPU up higher, they are usually good for 520mhz.
Eggenberg4Ever said:With mem @ 560 & core @ 520 I'm getting 5655.
Hmmmmmm. Expecting whopping results but not the case.
It is showing as anX850 Pro but I can't get anywhere near the results that some posters are getting using clocks like 560/560.
TBH, I'm **** scared of whacking up the numbers too high & frying my card; her indoors just wouldn't countenance my getting a new one![]()
Eggenberg4Ever said:3 GHz P4, 800 MHz FSB.
Just ran 3D 05 with clocks @ 520/600 & got a score of 5811.
Gonna play a bit of BF2 to check stability at these settings.
BTW, thanks for the help & advice, I'm sure you'd much rather be doing other things mate![]()
Eggenberg4Ever said:Nah, sounds like a headache mate![]()
Thanks for all the help though.
Any recommendations for my next GPU (bearing in mind it'll be around Xmas when I manage to get it).
Looking to spend around £150.
GoldenGlory said:How much should I pay for one of these cards second hand?
It's been flashed.
Mike UK said:Probs a daft question but does this work with the HIS Excalibur ATI Radeon X1800 GTO TURBO 256MB card?
locutus12 said:i would say between £90 and £110 depending on how well it clocks and if it has an R480 core with the RED circuit board, the blue ones were ok but they are R430 and dont clock as well.
locutus12 said:download this ISO Unzip it and burn to CD / DVD (if you have nero, open it, close the wizard and from the record menu select burn image then select the ISO, if you have easy CD creator, i dont have a clue )
http://fobi29.free.fr/x800gto2/bios/16pipes/X800GTO2MoD.iso (fixed as of may 06, may also work with GTO and GT ranges, try at your own risk)
step 1 boot from CD\DVD by changing the bios boot order to boot the optical drive of your choice.
step 2Select the menu option of your choice
it will confirm a succesful flash once done.
step 3 Enjoy!
Recovering from a bad flash....
step 1, install a pci graphics card,
step 2, boot from DVD\CD
step 3, select option 2 from the boot menu
Step 4 Reboot and Retry the flash.
EDIT**** Many of you are getting confused with regards to the difference between a zip/rar file and an ISO file. if you have Winrar installed it will show any ISO up as an archive, it isnt, winrar has nothing to do with it. just take the file and do exactly as it says above, just follow the instructions, and youl be fine
p.s. let me know how you get on![]()
Milkybar said:Locust, u r a legend....i have successfully unlocked 16 pipes and now have found new hardware.....Radeon X850 Series.....cheers mate...u have been a great help....
MilkyBar
