locutus12 said:if youve wrote the cd correctly, you dont have to enter a commend, it gives you 2 options, flash to 16 pipes (i think by pressing 1 then hitting enter) or flash back to 12 pipes (by pressing 2 then enter)
Milkybar said:i get 3 options
1: flash to 16 pipes
2: rollback to 12 pipes
3: enter a comand prompt
i entered option 1
it done some stuff and played a little sound and the told me to press any key to contiinues...
it then said successfully flashed to 16 pipes
and then it game me the
A:![]()
juno_first said:oops....
I flashed a x800 pro AGP with this boot flasher and![]()
No display now, even when the card is in a PC with onboard display the flashrom does not see the x800.
If I got a PCI graphics card, would that allow to reflash firmware ?
bertybassett said:does this work with all X800GTO2 cards or do you need a sepical one?
