danceMB said:Its just that I have got a Gainward (Golden Sample) 6800GT @ Ultra, and am looking for a better card than this, and if there is a cheap solution im all ears![]()
danceMB said:Its got 256mb ram, as for the benches I did a re-format last weekend so will need to bench it again and see what scores I get as I havnt done a test for a while now but will tonight.
creakindoor said:I have a Powercolor x800GTO, 256mb, AGP. Could I flash this card? and if so what differance would it make.
Cheers, Stephen.
david.n.c said:is this the driver i need to make my x800gto go like an x850? sorry if im being stupid
Eggenberg4Ever said:Hi locutus,
BTW, sterling work on this. That's some amount of work to be putting in on this.
My problem (if it is a problem) is that my GTO2 came with 16 pipes unlocked from Dabs.com & I did as instructed - burned ISO to CD, booted, flashed, no problem - however, my GOT2 is still showing as being an X800 GTO2 not an X850 PE (clocks remain as they were).
Have I done something wrong or have Sapphire put some kind of limiter on the GPU's? It's only about 5 weeks old.
Eggenberg4Ever said:Thanks for replying.
The circuit board is one of the red ones & it's showing as an R480 (using Everest utils).
I can up the speeds using the Trixx clocking util that came bundled with the GPU & currently I'm running:
Memory: 570
Core: 490
Maybe I'm being greedy or could it be Trixx that sucks? I've never read any good/bad opinions on it TBH.
Eggenberg4Ever said:Just uninstalled it![]()
Am I right in thinking that the Sapphire X800 GTO2 is flashable to X800 PE specs (is this what your modded BIOS does?).
When I did the BIOS flash the other night, ATT bench gave the following results:
http://i56.photobucket.com/albums/g188/Eggenberg4Ever/ATTBenchmarkResults.jpg
But any benches done since then have been between the unmodded X800 Pro & the PE marks.
Currently running at Core 500 Mem 570 but if there's higher speeds possible then obviously I want to get them unlocked.
