Hi Guys
Coming soon to OcUK and available for pre order, EK Watercooling Kits.
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
EK have stepped in and solved this problem. With each EK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike, transform your computer system
All of these kits offer the new EK Standard EN Nickel Plating method which ensures the highest quality nickel plating finish on your water blocks.
Overclockers UK recommends the use of Distilled Water or Watercooling Fluid which is available on this web-store.
To make the kit functional, the user needs 1Litre of Coolant.
Here is a video I have found that gives a great overview of the kit and also has links to unboxing videos of each component in the kit.
EK H3O Watercooling Kit - Supreme LT 120 **EN Nickel Plating** @ £122.99 inc VAT
The EK-KIT H3O - Supreme LT 120 water cooling kit is basic kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 120 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel LGA 775, 1156(i5) and 1366(i7) processors.
Supreme LT block is one of most efficient CPU blocks (value for money) and offers very good thermal conductive performance and low restriction. Single EK-CoolStream RAD XT radiator will fit in majority of watercooling cases and will succesfully take heat out of your system. EK-DCP 2.2 pump has been also proven for some time now by water cooling community and allows adequate and optimal flow for your kit.
"EK-KIT H3O - Supreme LT 120" water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (120)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
IMPORTANT:
To make the kit functional user needs 1l of distilled water, which can be found in every supermarket and petrol station.
Kit is easy to install, use and maintain (thorough installation manual is included). Further descriptions and specifications of individual items can be found in web shop.
Only £122.99 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 240 **EN Nickel Plating** @ £136.99 inc VAT
The EK-KIT H3O - Supreme LT 240 water cooling kit is a kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 240 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel LGA 775, 1156(i5) and 1366(i7) processors.
EK-CoolStream RAD XT (240) radiator will fit in majority of watercooling cases and will succesfully take heat out of your system (please check template of rad prior to installing in case).
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-CoolStream RAD XT (240)
- EK-DCP 2.2 Pump
IMPORTANT:
This kit can also be upgraded with an additional EK-VGA Supreme HF, EK-FB or EK-FC series waterblock!
Only £136.99 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 360 **EN Nickel Plating** @ £149.99 inc VAT
Supreme LT block is one of most efficient CPU blocks (value for money) and offers high thermal conductive performance and low restriction.
EK-CoolStream RAD XT (360) radiator will fit in majority of watercooling cases and will succesfully take heat out of your system (please check template of rad prior to installing in case).
EK-KIT H3O - Supreme LT 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (360)
- EK-DCP 2.2 Pump
IMPORTANT:
Kit is easy to install, use and maintain (installation manual is included).
Only £149.99 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme HF 240 **EN Nickel Plating** @ £159.98 inc VAT
The EK-KIT H3O - Supreme HF 240 water cooling kit is an advanced kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme HF 240 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel LGA 775, 1156(i5) and 1366(i7) processors.
Supreme HF block is best and most efficient CPU block (by independent reviews) and offers supreme thermal conductive performance and best high flow.
EK-DCP 4.0 pump has been also proven for some time now by water cooling community and allows adequate and optimal flow for your kit.
EK-KIT H3O - Supreme HF 240 water cooling kit includes following items:
- EK-Supreme HF - Nickel
- EK-DCP 4.0 (Pump)
- EK-Multioption RES X2 - 150 Basic
- EK-PSC Fitting 10mm - G1/4 Nickel (8 pcs)
IMPORTANT:
Only £159.98 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme HF 360 **EN Nickel Plating** @ £184.99 inc VAT
The EK-KIT H3O - Supreme HF 360 water cooling kit is an advanced kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme HF 360 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel LGA 775, 1156(i5) and 1366(i7) processors.
EK-KIT H3O - Supreme HF 360 water cooling kit includes following items:
- EK-CoolStream RAD XT (340)
- EK-DCP 4.0 (Pump)
IMPORTANT:
Only £184.99 inc VAT.
ORDER NOW
- EK-DCP 2.2 Pump
IMPORTANT:
ORDER NOW
- EK-DCP 2.2 Pump
IMPORTANT:
ORDER NOW
- EK-DCP 2.2 Pump
IMPORTANT:
ORDER NOW
- EK-DCP 4.0 (Pump)
IMPORTANT:
ORDER NOW
- EK-DCP 4.0 (Pump)
IMPORTANT:
ORDER NOW
